Installing V8 replaceing L6
cantaris
Need some advice. Removed the 165 L6 from my boat and I am going to install a V8 chevy. How do I determine the proper height to make the engine support stringers? I will be changing the transom.
Re: Installing V8 replaceing L6
Ayuh,...
Change out the Transon assembly,...
Stick an alignment bar thru it,...
Hang the motor on a lift, move it into position,..
Build the motor mounts to support it where the alignment bar says it wants to be...
