I would like to install a water separator on my Bayliner 175. (It did not come with one from the factory).
My questions:
Where should the separator be installed in relation to the fuel tank? Should it be higher or lower. My concern is if it is too low, the fuel will drain out of the tank when I go to change the filter. Should I put a shutoff valve between the tank and separator?
Also, are there any special fittings required? Will this type work (with a hose clamp?):
http://www.iboats.com/Moeller_Brass...1660755--**********.437741086--view_id.391597
The fuel line in the boat is 3/8"
Thanks
Lou
My questions:
Thanks
Lou
