Instead of a Boroscope?
myoldboat2
I'd like to get a peek inside my cylinders so I looked online at boroscope prices--those things are pricey! Does anyone use a different approach, like maybe a miniature videocam or some other idea? Just curious.
vegasphotoman
Re: Instead of a Boroscope?
Rent one maybye????????? used to have one at the car dealership I worked at in the past ...
why are you wondering about the cylinder walls and tops of the pistons...any particular reason???????
Does the engine run????
Spark plugs themselves tell a huge tale of the motor... see this link for photo samples of all types of issues...by NGK spark plugs...go HERE
Carbon buildup on plugs is normal...excess is not...
all plugs should be a little black...or slightly blackish = good running motor
oily plugs / lots of carbon buildup / gap almost bridged by gunk = excess oil...worn valve guides, aligned piston rings, worn rings/cylinder walls ...worn...excessively glazed cylinders = overhaul engine
all plugs look decent except one..is different...not a new plug..but super Clean...excessive fuel cleaning the plug off (check injector if EFI engine)...or water leak into cylinder...possible intake gasket leak..poss headgasket/ warped head....poss cracked head...or worse cracked block....
White plugs = running too lean = enrichen fuel mixture or overhaul carb.
Do a compression test.....if compression testing crank it over 3 to 5 times for MAX compression.....over 110lbs or better is decent...145 is better....
if the motor runs....is it knocking?
is there any smoke?
if so what color does it appear to be?
was motor sitting forever?
was motor submerged?
Blueish smoke out exhaust can indicate oil burning or excess fuel = check idle adjustment screws on carb / check gas is it new?
black is definetely excess fuel = check carb / efi
white is coolant on cars...so boats could be steam...white exhaust.. = water intrusion into combustion chamber
= worn rings...
shouldn't smoke out pvc/filler cap hole a teeny bit may be ok... ...if it does smoke, especially alot = it is worn out and tired!
hope this helps! I almost never ever used the boroscope in 14 years professional mechanic work Heavy Line tech at a Ford dealer....:) had an immaculate service record & Ford survey response
Ayuh,... Like maybe Pull the Head,..??
What's the Real Issue here,..??
myoldboat2
:D:D:D
There's no issue, really. When my carb was dumping fuel one time I got a bunch of mixed white and black smoke out the exhaust, probably just flooded really bad. I'm just curious and would enjoy having a look in there. I'm like that...
Had the plugs out not long ago, they were all slightly black. At that time, they had raw fuel on them because of the carb dumping fuel, not any more.
