Instrument cluster accuracy off after winterization
Paul Perryman
After winterization all gauge cluster readings seem off. Temp +20 deg from typical (but steady), Fuel +1/4 tank from actual, volts low, psi high. What do I check that could impact the reading of all inputs?
Don S
Re: Instrument cluster accuracy off after winterization
Check all the electrical connections to the module. Corrosion or loose connections can cause high resistance and give you overall high readings.
