Intake gasket question
maddog2
I have a question concerning the aplication of the intake manifold gasket.
My engine is a 1992 Mercruiser 4.3LX with a 4 barrel Webber carb.
question: Does the gasket go on dry?
Do you apply gasket sealer to the intake gasket?
I know that the intake has only the water inlet on the front where the thermostat is located. The back side of the intake is blocked off.
Bt Doctur
Re: Intake gasket question
Personally, all my motors get "Permatex Aviation sealant" around the water jacket ports only,
When you install the manifold, use a good amount of Black RTV front and rear
but don`t tighten the manifold down all the way ,let sealant cure, then tighten to spec.
tinman565
Personally..I put a thin coating of sealer around each port on both sides of the gasket. That way, I'm positive I'm not getting a vacuum leak. As the motor heat cycles (cold,hot,cold..etc)..the intake manifold bolts have a tendency over time to loosen up a bit. Everbody installs manifolds there own way, and in my opinion, a thin coat of sealer all around each port cant hurt.
Gary H NC
The bead on the front and rear lip i put on a little heavy and overlap it onto the gasket about one inch.
maddog2
I downloaded the Mercruiser service manual for this engine and it says to
(1) apply Perfect Seal to intake manifold gaskets and install gaskets on cylinder heads.
(2) place a 3/16" (5mm) wide bead of RTV sealer on block. Extend the bead 1/2" (13mm) up each gasket to seal corners.
The image in the manual shows the RTV sealer on the block and 1/2" on each corner. There is no mention of adding sealer around any water openings or intake/exhaust openings.
My problem is that the "backyard" mechanics calling themselves a boat repair center had silicone on both sides of the intake gasket. when I found water in the oil, I removed the intake and examined the gaskets. Im no specialists, but a friend showed me places on the gaskets where water was leaking into the engine. He says to only seal the block and the gasket corners as the service manual describes.
tinman565
I'm just telling you what I do on my stuff. We run high horespower drag motors (blowers, nitrous, and naturally aspirated combos), we build and repair other peoples motors...and built, and maintain our 502 Mag motor in our boat. I have never had a problem with putting a thin coat of sealer on both sides of the intake gaskets. The problem with some peoples repairs is that they dont take the time to do a proper job...dont pay enough attention to detail..and or just dont give a sh*t about you as long as they get your money.
Clean the head surface PERFECTLY with a razor blade, or a small wire wheel on a die grinder..then wipe it down with a solvent and let dry. Do the same on the intake. Make sure they are both spotless. Apply a light coat of sealer around all the ports on the head, install the gasket..then apply a light coat of sealer around all the intake ports and assemble the intake to the head. Tighten the bolts in a circular direction starting from the middle and working your way out. After the motor has been run and cooled down a couple times, go back and re-torque the intake bolts again. You wont have a problem sir.
maddog2
Thank you Tinman565 for your input and expertise on this subject.
