I thought this was an intersting pic. It's from a newsletter that I get. A power system line construction crew is using an implosive device to fuse a high-voltage transmission line to a dead-end device which is mounted to the transmission tower.
The picture your looking at makes it seem much worse than it really is. We just used a system like this when installing a grounding HALO system for a new 2-way radio system at work.
Basically its a fancy way of soldering or fusing copper cables together by using magnesium, with a gun powder primer. In the picture your seeing is the gunpowder primer going off. The gun powder stars the reaction with the magnesium which burns hot enough to melt or fuse the 2 cables together. It's actually rather neat to watch with all the smoke.
Bill
Well that's even cooler than what I witnessed our guys using. I stand corrected.
And your correct, primary transmission lines are not copper. They wouldn't hold up for very long.
Thanks for the info.
Bill
