Interlux Micron bottom paint removal
Toddavid
Anyone use this stuff to remove Interlux Micron bottom paint? Recommended by Interlux:
Interstrip Semi-Paste
Looking at a like-new fiberglass hull boat, very low hours, stored inside, with Micron bottom paint applied about 4 years ago.
I'm not a fan of bottom paint, as I only boat in fresh water, and store high and dry. Plus, some lakes I trailer to will not permit TBT bottom paint, and I don't want the fact that this boat is painted to even become a contention issue at the inspection ramp (even though Micron is not TBT).
Thanks in advance.
If the bottom was properly prepared for bottom paint, once you remove the paint, you will need to re-gel coat. its not just a remove and go thing.
you may want to check into dry ice blasting
