I've read over and over that certain abrasives should not be used on aluminum hulls to strip paint (like don't use a regular steel wheel brush, use a stainless brush-wheel) to avoid contaminating the aluminum.
Even Interlux states to use "aluminum compatible" sandpaper on their pdf sheet on refinishing boats... but they don't state which types of modern sandpaper are "compatible."
So I called their help line up to ask them, specifically, what they meant by "aluminum compatible" sandpaper - which specific types (not brands) were compatible?
The answer I got? "Oh, use 60 or 80 grit sand-paper."
The guy on the other side of the line reminded me of the general lack of professionalism and knowledge I see in many industries across the USA, but especially here in south Florida. I made the effort to convince him that grit-size is not a type, nor did it mean that the abrasive used was an abrasive that would be compatible with aluminum.
He left the phone for a bit, and came back with "Use the black stuff."
I'll tell you, fellas, if this is really what America is coming to, I want off of this train.
Again I pressed for specifics, and he said that it was really about the paper type... to which I said horse-hockey, it's about the abrasives used on the paper, not the paper itself (unless there is some really strange paper out there).
In the end he told me to start calling sand-paper companies because he really didn't have any basis for which the term "aluminum compatible sandpaper" was used on their brochures.
I am sure that someone, somewhere in Interlux, used to know something about the engineering considerations behind everything they develop products and suggestions for - but it didn't seem that way today.
