Intermediate bearing penta aq225 parts?
robjen1019
Took the boat out today, and had a squealing from the rear in reverse, and a growl when in forward. U joints are new this year, so Im looking at replacing the 2 bearing that are in the bell housing.
Is there a complete kit available, or do I need to order part by part. Does anybody have a complete part list of everything I need.
Thanks
Ro b
captmello
Re: Intermediate bearing penta aq225 parts?
You'll need two bearings #66 & #70 and the two seals #69 & 71.
Also want the two new orings for reinstalling the upper gear housing.
Your going to need a good set of snap ring pliers.
http://www.volvopentastore.com/CONNECTING_COMPONENTS_AQ_DRIVE_275/dm/*******.289243354--**********.687833920--store_id.366--view_id.315590
which drive are you running with your engine? 275 or 290? bearings and seals are the same BTW. Just curious.
let us know how it goes.
robjen1019
I have a 290 outdrive attached. Worst part is I just put motor in, I should have checked the bearings when I had it out. Guess I just got in to big of a hurry. Oh well, guess I will get some practice pulling the outdrive and motor.
Thanks
captmello
Well live and learn i guess.
That bearing job is not that bad. I had a heck of a time with the snap rings and so will you.:) Be ready to practice your patience.
Post any questions you may have along the way, Seems a lot of us have done that job recently.
BTW, did you regear your 290 or are you going to try running it the way it is?
robjen1019
I am running a 285 lower unit that came with the donor boat. But I don't like the way it handles, so Im going to switch the gears into the 290 lower. I really like the new found power. Now just to get all the kinks worked out.
