I have a 1998 merc 75 hp 2 stroke engine with less than 150 hrs on it. Recently I have been expierencing starting problems and engine stopping completely while in motion. I changed spark plugs/fuel filter and gas(fresh). Still I had the same problem. At times it would run and then it would just stop completly. i took to a reputable mercury repair shop and they found that i was not always recieving spark at all the cylinders. the ignition harness was ruled out since the repair shop hooked up a good harness and it still did the same thing. Finally it was concluded that it could be the stator. I replaced the stator (not cheap) . The engine ran fine at the shop and at home. The next day I started her up again and she started for about 2minutes and then cut out. I could'nt get her going again. Needless to say I took the engine back to the repair shop and am waiting for their diagnosis. There does not seem to be any pattern or instance when the engine cuts out it is really inter
mintent. any ideas?
