MH Hawker
- Jul 13, 2011
- 5,516
I have a 1996 mariner 9.9 / 15 hp 2 stroke, 0G119661, When the motor is cold it starts fine but after it has ran awhile and is shut off when you go to restart it was acting like a low battery, You can hear the solenoid clicking. I would have to turn the key a few times to get it to kick in and start. First thing I did was to fully charge the battery and clean and polish the terminals and connection points. Took it back to the slip and same thing for a few trips out. Took it back home and ran a solenoid test and it passed, so I pulled the battery and had it load tested and it passed fine. Even added a solar panel to keep it topped off. So I put on my spare starter and back to the lake. Same thing. So I got a new solenoid and replaced it just because, the one I replaced is less than a year old so I didn't think it could be bad all ready. On a short test run it started ever time even after a 2 mile run and shut down. Thats about where I am at the moment and due to 14 straight days of rain I haven't been back out to use it. Right now I am thinking that the solenoid was breaking down due to heat soak off of the motor, But I will see tomorrow I am planning on using the boat awhile.
I thought I would throw this out there, most starter problems are a control circuit or a power problem and are a simple cure.
