I am wrestling with an intermittent issue with my 1977 70 hp Evinrude (70773). The issue is most prevalent after the engine is run full speed on the water and heats up...and is then started and stopped at slow speeds moving from one fishing location to another. When attempting to then return to full speed, the motor only delivers half power when the throttle is wide open. It will run rough and stay in this mode for a bit and then normally the issue will clear with a drastic return to full power mode. The change is so drastic I thought linkage was sticking and kicking free but this doesn't seem to be the case. The issue has occurred going from full speed to half power, but only rarely.
Based on all of the good advice I have read from the responses that have been offered to others with similar issues on this forum, I have replaced the coils, plugs and wires, power pack, and rectifier. Have also replaced the fuel pump and have sprayed the carbs with carb cleaner
Upon returning to dock in this mode last time, I pulled the plugs to find that they were all wet with gas with the middle plug being noticeably wetter with bubbles around the spark plug electrode.
Would appreciate any advice on the next place you would look to tune or replace parts to clear the issue. The motor hasn't been heavily used over the years and runs like a champ except for this intermittent issue.
Thank you for any assistance.
