Hi.
2005 VP 4.3gxi in a FW 18 footer
Just got the boat back from marina for tune-up and u-joints. Ran fine the 1st day after small test drive.
New problem the next day.
When at low idle (just up from minimum idle, 5 or 6mph or so) and putzing through the no-wake zones the engine will momentarily go off, just for a split second. It triggers the 2 beep startup and sometimes idles back to where it was or sometimes a bit faster. Happens when cold or hot. Gauges say oil pressure and temp are fine. Sometimes it happens 3 times in a minute and sometimes it wont happen for 3 or 5 minutes.
A couple times it would diesel (like the old 80s cars) until I turn off the key and re-start it.
No problems at high idle (above 10mph or so) or at high speed. Do not notice any running issues otherwise.
Anyone have an idea of what I can check?
