Intermittent power on 15hp 2-stroke
easyvictor
I've got a Johnson 15hp 2-stroke, model J15REEA. Sometimes I can get full power (you can feel the difference), but most of the time it's kind of weak and you can hear it almost sputtering at WOT.
I did some experimenting and found that if I do a hard left turn, where everything in the boat shifts to the right, I can get full power! Then if I do a right turn, it seems weaker. Straight forward is somewhere in between.
I'm thinking it has to do something with not enough fuel making it into the cylinders, and the right/left thing could relate to fuel sloshing in the carburetor bowl? Is this a simple issue of fuel starvation, or more complex like adjusting the carb float? I've got the shop service manual but am no expert with 2-stroke engines.
Any thoughts would be useful.
Daviet
You might check the high speed jet in the bottom of the carb bowl, all fuel has to pass through it. Maybe it is restricted.
oldboat1
Electrical, maybe. Check under flywheel for binding wires; Check all connectors and boots.
