Dealing with an intermittent running issue here. Its all or nothing. When it runs its smooth, strong and great.
2000 19Ft Regal w/ Volvo/Penta SX outdrive and 4.3GL Volvo motor #4110188221 RWTR.
Had a situation about a week ago and thankfully we were very very close to the marina. While at minimum speed, the motor simply cut-out. no sputter, no nothing.
motor cranked great, but motor was dead to the world.
Thought I found the problem in the Main Wiring Harness Connector...while dockside, and inspecting everything, I wiggled the main harness connector (among other things), turned the key and voila! started and ran great. cleaned up connector, reseated it and all seemed good.
went out next day, short trip, no probs at all. yay. docked boat, returned 2 days later. and motor has never even coughed since.
Backing up a bit, when it does run, I barely crank it and it jumps to life. it'll crank like crazy now but never ever shows any sign of running, no sputter, no cough, no backfire, nothing. Has plenty of fuel and battery is new and charged full. (on a tender)
I'm about to just swap out the ignition switch because I cant think of anything else that would be causal to what I'm experiencing.
Is there an ignition switch test?
What else could it be...? When it runs, its flawless. Really quick starts. Using same gas as before. good battery charge. oil level is good.
Spent the morning again and now feel like I'm chasing my tail.
any help greatly appreciated. thanks.
Matthew
Matthew
