Intermittent squeak?
thedinz
Just started and its not constant, i have the 3.0 GS and there is an intermittent squeak right in the front of then engine dead center, sounds like its coming from the main pulley but not 100% sure, engine has good oil no water, i dont know if it just needs wd-40 or is the power steering going?
I just replaced plugs wires cap and rotor, when i started it up the squeak was there off and on, while idle. Its a new sound so naturally im concerned.
any thoughts?
any thoughts?
Ayuh,..... Welcome Aboard,... Sounds like it might be the belt,....
Carefully,.... With the motor idlin', wipe the inside workin' surfaces of the belt, with a bar of Lava hand soap,....
I carry a bar of Lava hand soap in my toolboxes, just for that reason,....
It doubles for washin' yer hands too,......
'bout the Best belt dressin' there is,... bar none,..... :D
