Intermittent Starting Problem - '98 4.3 LH
jtw
I have an intermittent starting problem. Sometimes the engine cranks, and sometimes I just get a click from the slave solenoid. But it seems to be repeatable. The sequence goes: 1st turn of the key, engine cranks. Second turn, the slave solenoid clicks. On about the 5th or 6th try, the slave solenoid stops clicking, too. I can start the sequence over by disconnecting the negative battery, and letting everything sit for a while.
Here's what I've done. I replaced the battery, because it was old. I followed the 'starting troubleshooting guide' on this forum using the 'solenoid clicks' section. The slave solenoid was giving inconsistent readings, so I replaced it. (Cheap and easy.) I checked the ground for the solenoid, and it is good. The small yellow wire goes to 12 volts when I turn the key. The large purple wire is always hot. The yellow wire is hot when I turn the key (if it clicks).
So, symptoms didn't change after replacing both the battery and slave solenoid.
Is it a bad starter? Is it ok to check the starter in place? If so, could I have clarification on how to do that?
Thanks.
dubs283
you can try jumping the primary yel/red terminal on the starter solenoid, if the starter cranks multiple times your issue is likely before that
dubs283
double check that all connections are clean and tight
jtw
Do you have a link for a procedure to jump the starter at the starter solenoid while it's in the boat? Sounds kinda dangerous. Is it just a jumper from the big red wire lug to the lug with the small yellow wire? How do I keep from getting a shock?
I restarted checking from the beginning. I disconnected the small hot wire from the slave solenoid, and put a volt meter on it. I get 12 volts when I turn the key to start alright, but I also have 1.5 volts with the key out, and I don't get infinite resistance. I'm guessing it's a separate issue.
