nervouslizard
- Aug 21, 2016
- 3
This Forum is an excellent resource. I recently joined so I could post my current issue. I have already performed diagnostics discussed in other places on this forum (Don S HOW TO)
Boat:
2006 Four Winns Horizon 183 Fish&Ski
Volvo Penta 4.3 CXI-F (3869306)
Issue:
Intermittent Start. It used to happen occasionally, now it happens more times than not. When key is turned, no click, no start, no reaction at all.
So my questions (hopefully someone can help with):
Boat:
Issue:
- Battery is brand new, fully charged, shows 12.6V, all connections are tight.
- When key is turned to Aux, all electric stuff works
- When key is advanced to start, nothing happens. No click from starter relay.
- Putting a meter on ignition switch: 12.6V at power lead, 12.6V at aux connectors when key is advanced to Aux. 12.6V at starter connector when key is advanced to start (yellow/red cable)
- Pulled starter relay and tested. When 12V applied (85/86), I get a click. Checked resistance on 30/87 and get 0 Ohms when 12V applied to 85/86. Infinite resistance when 12V removed from 85/86.
- With relay removed, I put the meter on slot 86 (C on Don S's diagram). I noted that this is an intermittent issue. I had the opportunity to observe both conditions today. When the boat would not start I was seeing 7.5 to 8V at this location (when the switch is advanced to start). Then the boat decided to start and so I pulled the relay and re-checked. Now ~12.5V at this location (when switch advanced to start).
- Jiggling, messing with the shifter/throttle does not seem to have any bearing on whether the boat starts or does not. Some times I can mess around with it for 10 minutes to no effect, then come out the next day and the boat will start. At best there may be a very loose correlation between the boat starting and messing with the shifter/throttle.
- What is between the ignition and the relay that could cause this voltage drop?
- Am I correct in thinking this has to be something in the shifter/throttle?
- Could this be the neutral safety switch in the shifter? This strikes me as odd as I think of switches as either being off or on, not half way.
- If it is the neutral safety switch, can this be replaced without replacing the entire throttle/shifter assembly
- Is replacing the neutral safety switch (and/or the whole shifter assembly) something a moderately competent DIYer could do or am I headed to the shop?
- Can anyone point me to some guidance as to how to get into the trottle assembly and do further troubleshooting or repairs?
