Internal tank or not
JGREGORY
My project boat is a 197? Wellcraft 165 Airslot. the floor is rotten and need replacing. What I was wondering is that since the floor is out would it be worth it to install permenante fuel tank under the floor. This would reduce the amount of foam needed, would provide bouancy, create more space topside, and would increase range.<br /><br />Should I do this or stay with the 2 portable 6gal. tanks? :rolleyes:
D
DJ
Guest
Re: Internal tank or not
Go for it.<br /><br />The in floor tank also provides some stability.
SystemF
When my floor gets done this winter that is one of the major improvments I am going to make. It will also allow you to make the weight a bit more equal.
