interrupt switch help
stillhi33
1985 mercrusier 170/470 i need to know how to connect the interrupt switch on the control arm to the engine and how does it work because i don't know if i have it in correctly i took it out over 2 years ago and forgot to mark it i have a tester on it and the wire stays disconected in the neutral position and if you move it forward or reverse it is connected i use a tester that makes a sound when the wire is connected together please help i have heard the switch cuts off the engine for a slight moment to go into gear so it does grind on the gears
Re: interrupt switch help
Ayuh,....
It activates Only when coming Out of gear.....
Not when going Into gear...
And,...
Only with the prop In the water....
stillhi33
thanks for replying so quickly and that i thank you but would you know where the interupted wire goes to???
Fishermark
The "interupted wire" simply goes to ground when the switch is activated.
stillhi33
is this any ground or does it go to something important to cut off the engine???
