Hello All,
So I posted a few weeks ago that I was restoring a boat, (thanks for all your help dOb) you saved me some blood sweat and tears. I didn't continue with restoring that boat. I wanted to be in the water fishing this summer not working on a boat. So I ended buying a 1985 bayliner open bow. So all it really needed when I bought it was a new battery. So I bought an Interstate 24 m Cranking battery. Took it out to the lake for the day with the wife and had no problems. I came home and parked the boat. Came out 3 days later and the battery was deader than a door nail. So I went out and bought a charger knowing that I would need it anyways to keep the battery topped off. My question is, is when I hook it up to the charger set on deep cell charge and set the amps to 10 the meter drops to zero and doesn't seem to be charging. I then set it at 2 amps and the meter goes almost to a 100% but hasn't quite tripped the fully charged LED light. Does anyone know what I should be charging this thing at and why would it go dead in 3 days? I left it hooked up to the boat when it sat but the only thing it runs is the fuel pump and to start the boat. The fuel pump switch was off so I don't see how it would drain the battery that fast. Any help is greatly appreciated.
