When the switch does activate it should not kill the engine if it's in good tune only cause
intermittant loss of ignition.
Um, if it's a standard shift interrupt switch it grounds out the coil. So activating it will in fact kill the engine. The only reason it's intermittent when shifting is that as soon as the engine "stumbles" the gears disengage and release the switch right away.
On my boat pressing the switch (located at the back of the engine, attached to a bracket that is also where the ends of the upper/lower shift cables go) does the same thing as grounding out the coil... the engine kills.
Erik
