Oddballmotorsports
- Jul 10, 2011
- 15
So Been wanting a boat for a while now.. I wound up trading a quad with my guy that I buy all my used atv parts from that had been sitting in the back of my garage for ever.. Here he is.. (a guy naming a boat a male? ok what ever lol) anyways its a 1972 Chrysler Courier 154 Walter P. Chrysler.. Get it?
One thing you can say, Yup that's orange.. its not from 1972.. noooo.. anyways, I'm keeping that orange hue.. needs work. go figure.. floors are good, but the upholstery isn't. so time to fire up the ole singer, and stitch up some groovy orange cushions.
its got a johnson 28 on it now.. good for umm iunno. 10mph? ooh. so the 28 will go away in favor of a 90.. which is what the boat is rated for.
no onto the problem. the transom.. its needing attention..
OUCH! ok so I knew about this.. completely okay with firing up the sander, digging this out, and re 'glassing it.. which is where the questions start...
It's not the most accessible area, its going to be a pain. so since this is a very structural area, it needs to be strong (obviously). however its mostly not visible, so I have two paths I think I could take.. The first, is take the cracks, drill the ends, bevel around it, fill the crack with cloth strips, then add on top of it, essentially bridging the crack. this would save from a ton of labor sanding down around the crack to make the panel level once repaired.
The other way, bevel out 4-8 inches around it, and fix it the way you would on an outside panel. when its done. it would look as it did when it left the factory.
now, as far as the transom itself goes, I can't tell but is it straight glass mat? or would there be some wood in there? I can peek inside the original mounting holes to see whats there, but at first glance, it looks like straight 'glass. and as far as repairs go, what resin should I use? I plan on using a standard non waxed marine grade poly resin, with a final waxed coat, then gel.
should I be using cloth or mat to repair this? and as far as the inside goes I think I want to brush on the gel coat, as given the area, spraying gel would make a pretty nasty environment. it doesn't need to be pretty, as it will never been seen. just needs to work..
and while I'm in there, would it be adventitious to add some aluminum brackets? to keep this from happening again? or what? I know its almost a 50 year old boat, so take that for what it is..
as far as accessibility goes, the part that closes in the transom (no idea what they call that) seems to be non structural, which is also showing some cracks. I could cut that out for better accessibility and then reattach afterwards. don't mind doing that, just a ton more time if I have to.
So I have a couple of months before it gets too cold to lay resin, I'd like to get that taken care of so I can focus on the "new" motor, and upholstery over the winter.. so what do y'all think, do I have a solid plan of attack? are there any time or labor saving tips on repairing the transom? I'm all ears.. The boat is in pretty good shape overall, and I've thought maybe buying a newer 4 stroke once I get everything else sorted out...
