Tacklewasher
- Sep 18, 2002
- 1,588
So I have an issue with my prop ventilating and I also want to use a jet leg at times on this motor. So I need to lower my motor for the prop and raise it for the jet.<br /><br />Understand I converted this boat from a OMC Stringer I/O to an outboard and missed on the transom height calculation. So to get the boat working better with the prop, I would have to cut the transom and re-work it a bit. <br /><br />I also run this boat in the Fraser River and have bought a jet leg for that use. I plan to swap to the prop in the spring for the lakes and put the jet on in the fall for the river.<br /><br />One option I am thinking about is to get an extension for the motor and raise it to the proper height (maybe 3 inches). Then I would remove the extension when putting on the jet.<br /><br />But I'm wondering if a jack plate would work as well. It would have to be adjustable and I'm concerned about the extra strain on the transom.<br /><br />So, any ideas one way or the other?
