Is acetone safe for cleaning fiberglas surfaces( windsurfing mast)
ittiandro
I thought this topic is within the scope of boating, since windsurfing is a marine/nautical activity..
I found a couple of small hairline cracks towards the bottom of my windsurfing mast,( probably while dragging the mast ). Nothing structural, only superficial, but I wanted to strengthen it , just in case, by wrapping a 2 “ wide fiberglas patch ( Bondo polyestyher resin) around the dented section..
While working on the fiberglas patch I have slightly smeared the area with resin . It is only some light residuals of hardened resin, small lumps at most . They are almost imperceptible visually, but I want to remove them because they have taken away some of the glossy surface of the object and are a bit rough at the touch.
Can I clean them with acetone without risking to damage ( or even dissolve ) the underlying original material?
The mast is 75% carbon and 25% fiberglas ( or epoxy, I'm not too sure) and I don’t want to clean by sanding because this will defeat my purpose and further dullen the glossy surface.
Thanks for your input.
Ittiandro
ondarvr
Acetone won't damage epoxy or polyester resin if you're just cleaning it, but if it's been painted it could damage the paint.
gm280
What about a razor blade scraper to remove the resin? If you use a very shallow angle, it would cut the resin off without bothering the surface material. JMHO.
Ayuh,.... Welcome Aboard,.... Acetone will not effect hardened poly resin, so yer plan ain't gonna work,....
I suggest fine sandpaper, 'n buff it out after to regain the gloss,....
sphelps
I agree with Bondo ... Post up a picture or two .... We love pics ! :welcome:
ondarvr
Acetone will normally remove resin that's smeared thin on a surface, heavy drips, no. Resin won't cure well in the thin film, so although feeling hard, it's not fully cured.
