Is changing CDI switchbox difficult on sportjet 90
Ohio79
I took my 94 sea rayder to mechanic due to the top cyl not getting spark. He said the switchbox is bad and suggested it be replaced. I have the CDI unit in there now and found one online for 1/2 of what he's charging. My question is I have decent mechanical skills and doing it myself will save me almost $100. How hard is it to replace and is it changing one wire at a time easy? Thanks in advance
pnwboat
Re: Is changing CDI switchbox difficult on sportjet 90
Pretty simple to change the switch box. Like you said, one wire at a time. Might take a digital photo before you start, and hopefully the mechanic has diagnosed it correctly.
jerryjerry05
Depending on the model and serial#s.
It's a simple wire for wire swap.
Pics?
They used 3 different ignitions so it might be easier on one model than the other?
Getting USED parts???
Ohio79
Ok now im confused. I checked the switch box against the motor serial number and it said i should have part # 114-7778. The unit thats actually on the motor is a 114-4953. What's is the difference and could having the wrong switch box what causing or cyl to not spark
