captainnate
- Apr 19, 2011
- 195
mercruiser 120 (sn 3331071)
MC1 outdrive
1972 Starcraft Nova aluminum boat
I replaced the transom plywood, and I am in the process of trying to get things back together. The alignment seems wrong. I thought it was aligned, but then I rotated the engine, and the alignment is off. Is the engine couple warped? It sat for a long time; maybe it was in the wrong position and stayed that way. Also, the front mount is all the way to the lowest point, which also seems suspicious. I have not replace the gimbal bearing yet, don't know if that matters; it seems to be in okay shape.
MC1 outdrive
