Re: Is it ok to run out the fuel in a 2 stroke?
You really don't run the carbs totally out of fuel. Some remains in the bowl. There are a couple schools of though on this, but my feeling is that if you have a small motor and remove it for transport, then run it dry but expect a little to dribble out of the carb(s). If the engine stays on the boat, treat each tank of fuel with stabilizer and just shut the engine off. The stabilized fuel will not gum things up and since the bowls are full, there can be little air to cause problems. With empty, or near empty carbs condensation, varnish and crud can build up.
