CLi87
- Sep 21, 2018
- 213
I'm trying to remove the transom assembly on a 93 Sea Ray Sundancer that's very badly corroded, I have all 8 nuts removed and it'll barely budge, I may have knocked the top bolts back a mm if even that and the rest of the bolts are super corroded, can't even get the inner plate off. I was wondering if it's ok to heat up the bolts with an oxyacetylene torch or should I use something a little less powerful like a propane torch?
