is my 1990 200 gt good or not
dannyman3
i have a 200 gt 1990 it runs ok it has a little miss on takeoff but runs 20 ft heavy boat 64mph turns 6100 rpms ive done a compression check it 70 on all 6 cyl's ive had some tell me its done needs rebuilt then have some tell me its fine becase they all are the same i looked up this and there is a lot of these 200gt with low compression does anyone know what the deal is with these having low compression should i run it till it wont run any more any help will go long way thanks hope to here something bout the compression
tashasdaddy
Re: is my 1990 200 gt good or not
compression gauges are all different, they read different. the main thing is that the reading are consistent. with in 10% of each other. your are fine, those bigger engine have lower compression than the smaller ones. you might do a decarb, and bring it up some, probably never done in 19 years. see TOP SECRET FILE.
your little miss, could be a clogged mid speed jet, or a link n sinc adjustment
keep oil in it and tuned, run it till it shows you it wants to stop.
