Is my 98 Force 40hp Trashed?
robert0209
I have a 98 force 40hp. I've been having some problems with it, but up until some unrelated electrical issues , it was running alright. Well, I decided to do a compression test before diving into the electrical, and I found that the top cylinder had low compression...about 85psi. I dropped a little bit of oil in the cylinder and the compression jumped to 115, which is where the other cylinder tested out at.
Does this mean my motor is trashed, and I should not waste money on electrical parts? Any guidance is appreciated. I just don't want to spend the money I could be saving up for a new motor, if this one is trashed.
Frank Acampora
Re: Is my 98 Force 40hp Trashed?
No, it just means that one or both rings are stuck in their grooves. Try spraying in some solvent and turning the engine by hand, or add a little snake-oil (carbon treatment) to the gas and run it.
robert0209
Thanks for the reply Frank. I was afraid that it meant it was game-over for this motor. I hope not as I like this motor, and it's been very reliable up until recently.
