Re: Is my fuel mileage good?
No matter the actual calculations are correct, there is no doubt regarding the principle. A 1.6 litre 4-cyl 75 hp 4-stroke with the latest in electronics compared to a 3-litre V-6 225 hp 2-stroke with 4 carbs... even the fuel supply line has to be heavier.<br />It produces more than 3 times the power, so expecting a mileage like the 75'er makes no sense.<br /><br />Add to this the simple fact, that the way you squeeeze the handle affects comsumption as do the way you use your boat. Cruising with a maximized prop takes a lot less than pulling skiers all day.
