Hello all,
We bought a 74 Johnson 50hp (50ESL74M). Initially, the motor started and idled perfectly but bogged when we tried to reach WOT. Based on what I read here, and the manual, I thought it was the fuel pump as it was original. I replaced the fuel pump and took apart the carbs and they looked clean and undamaged. I did not adjust the floats. The inlet needle valve and seat looked new also. Anyway, we took the boat out again and it did basically the same thing. Bogged when trying to get to WOT but this time it idled very fast. We took the boat out of the water again and brought it to the shop that the previous owner had used for years.
The mechanic called me today and said that the Low Speed Needle Valves were wide open and that they were missing the retainers. So he dialed the needle valves in, put on the retainers and put it in a test tank. He said the boat rev'd right up using the control box and he thinks that is all that was wrong and by the way, that'll be 175 bucks.
Now for the questions. I cut and pasted the part of the manual into this post. Why do I not see the retainers he is referring to. The other question is, if the Low Speed needle was wide open, would that affect trying to get to WOT and higher RPM's. I am pretty new at this, but I thought that would only affect the idle speed?
Is it possible the previous owner adjusted the motor to compensate for a faulty fuel pump?
Thanks for looking...
