anonOmattie
- May 26, 2017
- 42
hello folks! i've got a small problem with the electric starter on my outboard engine. 1986 merc. 25XD long.
let me describe the observations i did so far:
- the electric starter will not crank when turning the key
- the choke does not work from my console
- the starter engine will run when connected directly to a power source
- the starter engine will (sometimes) crank when the engine is already running
- the choke will not work when the engine is running
my first few runs the starter worked perfectly. after a few weeks it would sometimes crank, sometimes not. after a few months it would not crank anymore. there was still a loud clicking noise, but eventually that also stopped.
at first i thought the starter was broken (as i had that problem earlier on another OB), but after cleaning the inside and the brushes, it ran no problem. now i'm thinking it is the solenoid that is causing the problem.
ill measure the voltage of the battery when trying to crank the electric starter, and when the engine is running.
could you all please share your thoughts when reading this? thanks in regard!
