is my transducer correct?
Crazydawgs29@gmail.com
1st one I ever installed and wondered if it was in the correct spot. Finder is a Lowrance hook 5 finder/plot charter
ajgraz
Looks good from the side. Got a picture from the rear?
Bayou Dave
From the photo angle it looks like it may be a little low and too close to the center. Most I have seen are further away from the prop area.
A rear angle photo would help.
Instructions said it had to be greater then 3 inches away from tip of prop. I'm about 4ish. Never said how high so I assumed just below the bottom of boat.
Bayou Dave
That angle looks a lot better. You are far enough away from the prop. It might be a tad low but should flip up if you hit something in the water. I would leave it like it is.
gm280
Looks about right to me. Try it out and let us know how it works. :thumb:
