steelpony5555
- Aug 15, 2016
- 18
Ok I have just got this boat. The previous owner had a little trouble starting it when I bought it. Smoked like hell when it did start. Soooo I got new plugs and using the ears she started right up on the first turn of the key?????? Smoked like crazy but I have seen outboards smoke like crazy and then calm down and just smoke a little. I ran it for couple minutes and smoking never ceased at idle. It should have cut the oil to 1:150 at idle???? So do y'all think my VRO is pumping too much oil in and I should disconnect it. I worry bout it getting too much oil at idle if I am mixing at 1:50 and still having fouled plugs.... Or should I take the boat out and run it and see if it calms down.....Not sure when the last time it was run other then when I bought it.....Thanks
