pecheux
- Jun 9, 2006
- 1,200
Good day,
Got the Johnson 9.9hp out of hibernation today and ran it in a garbage can filled with water. I normaly just put the muffs on with the water hose supplying the water, but have new neighbor that was on night shift so I prefered keeping the noise low profiled. The tell-tale water outlet had it's normal flow of cold water and the 2 holes below the motor base were also spitting out warm water as usual and more so as I reved up the motor. But I noticed for the first time that when the OB was running low idle with gear forward engaged there was hardly any noticeble water coming out of these 2 holes although the tell tale water was still a steady flow of water. Is this normal ? Is tell tale sufficent proof the impeller (water pump) is working ok ?
Thank you.
Thank you.
