Is there a life expectancy for an axle
polk county
I have a 15 ft. aluminum boat with a 25 hp motor and a continental trailer with a square, tube axle and 12 in tires. The axle bent and now the tires are wearing unevenly on the insides. It took 8 years and over 400 local fishing trips for the axle to finally bend. Is this a long life span for an axle? Should I replace it with a heavier duty axle? Thanks for the help.
H20Rat
Re: Is there a life expectancy for an axle
That is a fairly light load, that shouldn't have bent an axle. Axle life isn't limited by time, it usually rusts away first. If it bent, it was overloaded at some point. In your case, the boat is relatively light, but is it stored with the plug out? One good rain storm could easily drop a thousand pounds of water into the boat.
polk county
Hit the nail on the head. There was one time where the plug was left in and the boat filled up with water. I llooked at tractor supply and say mostly round axles with the hubs already installed. It there an advantage to round axles verses the square tube?
lckstckn2smknbrls
Is it square or is the axle "U" shaped with an open bottom?
I would replace it with a 2000 lb axle.
polk county
thanks for the reply, it is a 4 sided square tube
lckstckn2smknbrls
Round things are generally stronger than things of other shapes. If the axle is rated at 2000 lb's square or round won't matter.
MH Hawker
well my old boat trailer was a1968 that i put around 100,000 plus miles on it all on the same axle
