Ok,<br /><br />I finally acquired a large capacity toilet tank for the house. The tank on this baby is huge! <br />Like the good 'ol crappers you use to see in your Grandparent's homes!<br /><br />This tank does NOT have the bolt holes through its bottom like today's normal ones do.<br />It does however, have holes at the top of the tank on its back. I assume these are to secure the tank to the wall.<br /><br />QUESTION:<br /><br />Do you think this tank will fit my standard Kohler bowl? <br />Obviously I won't be using the bolts at the bottom of the tank, but what about the outlet?<br />Does anyone know if the outlets are the same size? (It is approx. 2 1/4" od)<br />If they are, shouldn't I be able to toss some new seals in, and drop it on my existing bowl?<br /><br />Then theres the matter of bowl capacity. Will the larger tank work with the 1.6 gallon bowl?<br /><br />Thought I would ask before I start tearing things apart. <br /><br />I suppose I could maybe find a tank at the hardware store and measure it. My toilet isn't that old, maybe 3 years.<br /><br />Thanks,<br /><br />H.
