Is there any tips on removing my 120 hp force engine?
Spiderman626
Ok so I got a 1990 Boat with a 120 HP force engine in it, I had to put a new head gasket on first thing as I was told by the seller. I replace that and the boat seemed to run find for about 15 min. I checked the compresson and all four was around 115 to 120. I cleaned the carbs and notice when i would try to crank it back up it would hydrolock on me so when I would removed the plug on my #4 or should i say the one on the bottom there was a milky color on my plug and i once again removed my head and could see the milky water coming from my exhaust holes. Does anyone know what that could be from I was told it may be my exhaust plate or gasket... of which i would need to remove my engine to get to.. I really need help. Thanks for anything you guys may be able to help me. Thanks Jerry
