Is there any way to test an 5.7 liter Mercruiser Thunderbolt Ignition Amplifier?
Status
Not open for further replies.
gooeyny
I have a 1990 Thompson 26" fisherman with a 5.7 liter mercruiser with an alpha outdrive. Got towed off of Lake Ontario yesterday when engine died. Engine had no spark at plugs or at coil. Per service manual check for 12v at + side of coil, that was good, then checked for 12V at the distributor, also had 12V there. Then checked for spark from coil lead to ground - no spark. Tried known good coil - still no spark. Manual says that if all the above are true it is the ignition amplifier mounted on the exhaust manifold. As this is like a $300.00 part I want to be very sure it is indeed bad. Is there any way to bench test amplifier with a meter to confirm it is bad? If not could a Mercruiser dealer test it for me? Any help would be greatly appreciated. Thanks!
Don S
Re: any way to test 5.7 liter ignition amplifier?
There are no tests for the module itself, what you do is test around it.
Re:Thunderbolt IV Testing:
if you get spark from the coil tower then the module is working
your "expert tech" should be able to figure this out rather easily
if you set your meter to dc volts and connect the positive to the negative side of the coil and the negative side to a good ground, with the ignition "on" hold the white/green wire from the module to ground for a few seconds, if the voltage drops to 7-9 volts, then returns to 12, the module is good...,https://forums.iboats.com/forum/eng...es/455011-apha-one-v6-thunderbolt-iv?t=444003
muc
"Retired" Association of Marine Technicians...
No The 3.0 never used the Thunferbolt system. Maybe start a new thread about you problem?
Tycer
Howdy Don, can you repost that picture in post #2?
Kinda tough,..... Don passed away several years ago,......But there is now some updated info above that ought to help.
Status
