ready4itall
- May 4, 2015
- 49
1979 Evinrude 140hp
Model No. 140943R
Can't find online if its a 2 or 4 stroke. Thanks in advance
Model No. 140943R
Good luck They are not generally available on line but you can buy one from KenCook at Outbordbooks.comThanks.
Im gonna. Try to look for an owners manual.
Since you have no idea how to tell whether an engine two or four stroke, here goes: Look at the engine cover. If it is a four stroke (especially older ones) it will say so on the cover. If that doesn't work remove the engine cover. Most small to midrange HP two strokes will have a plastic oil container on the side of the engine. TWO-STROKE oil is put in this reservoir and it is mixed automatically with the fuel. Some two strokes have a separate oil container mounted at the stern of the boat near the engine. If the engine is a four stroke, you will find a dip stick like the one on your car (you do check that once in awhile -- not????). On a four stroke, engine oil goes into the crankcase. A four stroke engine will also have a valve/cam cover just like your car. Two strokes have a very flat cylinder head where the spark plugs screw into. Four stroke engines have spark plugs that are generally screwed in at an angle. If you still can't tell -- then before you even attempt to operate this boat, have someone who does know the difference show you how to check and operate it.
