Is this a gearlube monitor?
MahtyMaht
Stepson's 1988 Merc - I don't see pics that look like this in the manual, but it looks like a duck, quacks like a duck therefore, I think it's a gearlube monitor. It makes me nervous that I don't see any lube in there. At the moment, I'm focused on other problems with that boat, but at some point, I'm going to want to establish that outdrive's status.
Bt Doctur
Re: Is this a gearlube monitor?
Thats for the trim tabs ,not the outdrive.Boat Levelor it looks like
Nope,... It's a Trim Tab hyd.pump,... Lenco I think....
Don S
Boat leveler trim tab pump. Pictures in link below.
http://www.insta-trim.com/main.html
PS: Merc did not use Gear lube monitors as standard untill 93 I think, maybe 92 and that was on the Alpha I Gen II outdrives only. Not your 88, which would be an Alpha One.
MahtyMaht
Mystery solved. Thank you, gentlemen. Now, back to my crankcase full of scudge......
