can I drain this plug and winterize my boat?
Just to be clear, Lower unit in basement, block and exhaust manifold drained and boat is winterized.
OK I see. I need to also change the oil fog the motor etc. However if I take the above steps will this prevent any water/freeze damage to motor?
Yes. Just make sure the hole is open, use a wire or something to clean it out.
