Cricket Too
- May 14, 2003
- 1,732
Hey guys, I have a Sears battery charger, it's about 15 years old. It's just a simple 12V 10amp/2amp and 6V 2amp charger, with a 50amp engine start feature, nothing to big or crazy. This charger has always worked well for charging up my Deep Cycle boat batteries and the occasional car battery.<br /><br />Went to charge up my Deep Cycle's and noticed that when I plugged the charger in the needle in the little meter on the charger was bouncing around slightly, rather than being a steady reading as it always has been in the past. I tested the electrolyte in the cells with a hydrometer, then put the batery on charge for about 6 hours on the 12V 10amp setting. Came back to take it off and saw the charger's little meter was all the way down, as it would be if the battery was fully charged, took the charger off and tested the elctrolyte again, and it didn't go up 1 bit. I got the exact same reading on the electrolyte as before 6 hours of charging.<br /><br />So I wondered if maybe this charger was on it's way out. Took my handheld volt meter and hooked it up to the charger leads, then plugged the charger in, and only got about 11.2V on the 12V 10amp setting. I figured that in order to charge a battery it would have to be putting out at least 12.8 or higher, but I guess I could be wrong, so basically my question is, is this too low of a reading and should this charger be putting out a higher voltage than 11.2v when charging? Thanks, Mike.
