Is this engine worth changing?
Thumbtack
Mercruiser 260 v-8.
All cylinders are up to about 170 compression except for one which is showing 105. If I put a few squirts of oil in it it gets up to 120-125 so it must be going past the rings. We haven't ran the engine yet in the water and I was wondering before we go through the process of putting everything back together should we bother with the engine. This one is a little close to call.
Re: Is this engine worth changing?
Ayuh,... Flip a coin,... It'll probably run thru the season...
JustJason
That oil may just be gettin shot right up your compression tester....
1. try a leakdown tester instead of the oil "trick"
2. pull the valvecover associated with that piston. Have a look at the valves to make sure they are the right height, the rockers aren't loose, rocker studs haven't pulled....
rbh
one thing I have relearned latelly is that boats that idle for a long time have a better chance of getting valve problems than ring problems.
if you fish and do not open up the engine once in a while you "could" get a chunk of carbon stuck to the valve or seat?
just a thought.
rob
gadget73
+1 on the leakdown test. It will tell you exactly where the compression is going.
