Is this fully shifted into reverse? Alpha one.. (pic)
Bumperlt12
Having a hard time getting reverse to engage. Is this what full reverse is supposed to look like? Should it be a full 90 degrees sideways? If I stick a large flathead in there and push it just a fraction more, the prop locks up like it should.
they weren't lined up once when I put drive on and I fear i bent the shoe
Click image for larger version  Name:	Screenshot_20200828-154705_Gallery.jpg Views:	2 Size:	1,007.2 KB ID:	10923696
alldodge
Was the drive split?
Edit: Scratch that, you did bend the shoe, and no it won't be 90 degrees
Bumperlt12
I split the drive just now. The shoe looks fine, but the washer was all jacked up.. so I reflattened it and im putting it back together.
Getting the shift shafts to line up is a bear.
Bumperlt12
Got it back together... and its like the shifter cable is just millimeters away from pushing it into reverse enough to catch
harringtondav
In Alpha Gen 2 12 o'clock forward is FWD, 11 o'clock is N, and 10 o'clock is REV. ...If it shifted OK before you did your work, it sounds like something got bent. 9 o'clock - 90 degrees says something is wrong.
See if your foot clocks correctly in FWD. If it's off CCW, and it's a fight getting the drive back on, I'm guessing the lower shift shaft has been tweaked off.
Bumperlt12
This is a gen 1. Everything worked fine, albeit stiff.
Because it was stiff, I did chris' youtube procedure to improve it (even though it didn't help with upper red cable). Well, the shifter isn't stiff anymore... but I lost reverse.
if I take the lower unit off, I can get the prop to lock up in either direction by hand. I lock it in forward with a bungie, reinstall.. still no reverse.
Is there a downloadable manual I can study??
dubs283
yes, the shaft is bent. can be straightened, this is your first step
with drive split and locked in fwd is the foot straight fore/aft?
Bumperlt12
Locked in fwd
locked in reverse
