Is this how you test a fuel pump on 99 Yamaha VMAX 150 ?
johninmo
Hello I have been told that the way to test a fuel pump on a 99 Yamaha 150 is take it loose from the block put your finger over the hole on the back and pump the primer bulb if gas comes out the hole its bad I have two pumps one has gas that comes out the other dose not,common sense says I have one bad pump but I didnt want to spend the money on one until I verified that this is how you test them
Thank you very much
99yam40
Re: Is this how you test a fuel pump on 99 Yamaha VMAX 150 ?
fuel should not come out the pulse port to crankcase, I would replace both.
If one goes how far is the other from doing it also
johninmo
Thank You 99yam40 I appreciate your time in answering my question
johninmo
Thanks again 99yam40 I havent had alot of time latley but I put the new pump on tested it today on the hose and it ran great if all goes well I am going to the lake tomorrow
