In trying to help diagnose why my 84 90hp cyl is sputtering/misfiring I popped off the fuel pump to take a look. There is a little bit of fuel pooled behind the fuel pump diaphragm. Behind the upper hole you can see in the pic there is a bit of fuel that was sitting there. The upper section of the pump diaphragm/gasket is also wet with fuel in that area. The lower hole only has a drop or so of fuel sitting there. Is this normal for there to be a little fuel in this area...?
