Is this normal?
Djarjis
The boat will not start if I just leave it in neutral. I have to rev it a little when I start it for it to stay on. When I put it back in neutral it cuts off. I was wondering if the picture I posted is normal. And I think that's the neutral cut off switch. Other pictures I've seen the lever was in the center.
gm280
I have to be honest with you. I can't make heads or tails out of that picture concerning a neutral start switch. What type engine and make, HP, year and such for starters?
Djarjis
Mercuriser 4.3L LX Gen+ GM V6 1997 alpha one gen 2 stern drive. It's a plunger assembly on the shift bracket.
Tnstratofam
That's the shift interupter. At least I think that's what it's called. Anyway it is supposed to momentarily stall the engine as you shift from neutral to forward or reverse. It may be out of adjustment. Or your shift cable may need adjusting.
UncleWillie
Yep! That is the Shift interrupter.
It allows the drive train to unload by stalling the engine for a slight fraction of a second when attempting to get back into neutral.
The plunger switch that is on the upper "Bump" in the picture, should be slightly lower and in the "Notch" between the two bumps for the engine to run.
If your shift cable going back to the drive is Corroded/Rusty and Dragging, the switch will not return to the center on its own.
Djarjis
well i realized that the shift shaft was not lined up with the upper shift shaft. so i fixed that and then the shift interrupter moved back into place. now the problem i am having is that when it is running in neutral and i shift it into gear (forward or reverse) it stalls. i know the cable is not bad because i just replaced the bellows recently and there is no hesitation with or kink in the cable. i fully analyzed the cable before i put it back. i watched the shift interrupter move as i shifted it into gear and the plunger will not move back to the "notch". any input would be greatly appreciated.
NYBo
Make sure the idle speed and mixture are set properly. If you mean that the shift interrupter switch doesn't pop back out, you should probably replace the switch. Cleaning it may let it work for a while, but why risk having it fail out on the water?
UncleWillie
The Interrupter will come off center whenever the input cable/shaft from the throttle and the output cable to the drive do not follow each other.
Getting into gear is normally not a problem because the dogs in the clutch want to grab each other.
When trying to get out of gear and back into neutral the opposite is true, and the clutch dogs do not want to let go.
The input shaft moves but the output shaft does not follow.
Once the forces get high enough, the interrupter kills the ignition, the prop unloads, the clutch disengages and the output shaft releases.
An instant later, the ignition re-energizes, and all that is felt is a slight hesitation in the motor.
All this happens in less than one revolution of the engine and is usually not even noticed unless you anticipate it.
The interrupter will normally only function while the propeller is under a load while pushing the boat through the water.
It will not function when reducing the throttle from speed and going directly into neutral, or while on the muffs on a trailer with the prop not in the water.
If it is stalling going INTO gear, the output shaft is binding. Water in the drive housing is the usual culprit.
Disconnect the Output shaft and move it back and forth
If it will not move smoothly with light finger pressure, a new shaft it in your future.
Once you experience effort it takes to get to the far end; The low cost of the shaft does not warrant trying to clean up the old one.
Do it right, and you'll only need to do it once!
